[GRASS-dev] heads up: changes in the UI of i.cutlines
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 15 04:25:05 PDT 2018
Hi all,
If any of you use i.cutlines, watch out: in order to simplify and
clarify its interface, I changed some parameter names and reduced the
output options to just the vector tiles.
So there has been a change in interface to the module.
I also added the option to provide the module with existing cutline
vector maps for guidance.
https://trac.osgeo.org/grass/changeset/73551/
Moritz
