[GRASS-dev] Error loading/rendering vector maps in g.gui
Anna Petrášová
kratochanna at gmail.com
Tue Oct 16 10:59:33 PDT 2018
Perhaps related to changes in parser in r73525?
On Tue, Oct 16, 2018 at 12:14 PM Eric Patton <eric.r.patton at protonmail.com>
wrote:
> Hi , I have run into an error using Grass 7.7 svn revision 73556; when I
> open g.gui and try to add a vector or raster map and display it, I
> encounter the following error:
> Traceback (most recent call last):
> File
> "/usr/local/grass-7.7.svn/gui/wxpython/core/gthread.py",
> line 121, in OnDone
> event.ondone(event)
> File
> "/usr/local/grass-7.7.svn/gui/wxpython/core/render.py", line
> 468, in OnRenderDone
> self.updateProgress.emit(layer=self.layer)
> File "/usr/local/grass-7.7.svn/etc/python/grass/pydispatch
> /signal.py", line 229, in emit
> dispatcher.send(signal=self, *args, **kwargs)
> /dispatcher.py", line 349, in send
> **named
> /robustapply.py", line 60, in robustApply
> return receiver(*arguments, **named)
> File
> 742, in ReportProgress
> self.renderDone.emit()
> **named
> File
> 649, in OnRenderDone
> raise GException(_("Rendering failed: %s" % msg))
> core.gcmd
> GException
> Rendering failed: Overlays multiple PPM image files.
> Usage:
> g.pnmcomp input=name[,name,...] [mask=name[,name,...]]
> [opacity=value[,value,...]] output=name [output_mask=name]
> width=value
> height=value [bgcolor=name] [--overwrite] [--help]
> [--verbose]
> [--quiet] [--ui]
> Flags:
> Parameters:
> input Name of input file(s)
> mask Name of input mask file(s)
> opacity Layer opacities
> output Name for output file
> output_mask Name for output mask file
> width Image width
> height Image height
> bgcolor Background color
> ERROR: g.pnmcomp: Sorry, <-> is not a valid flag
> ERROR: g.pnmcomp: Sorry, <o> is not a valid flag
> I am using the following software:
> GRASS version:
> 7.7.svn
> GRASS SVN revision:
> r73556
> Build date:
> 2018-10-16
> Build platform:
> x86_64-pc-linux-gnu
> GDAL:
> 2.3.2
> PROJ.4:
> 5.2.0
> GEOS:
> 3.7.0
> SQLite:
> 3.22.0
> Python:
> 2.7.15rc1
> wxPython:
> 3.0.2.0
> Platform: Linux-4.15.0-36-generic-x86_64-with-LinuxMint-19-tara
> There were no errors during compliation or make. Any help appreciated,
> *~ Eric*
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181016/ee7a3852/attachment-0001.html>
