[GRASS-dev] OSGeo4W-winGRASS 7.7 with new gdal, geos, proj4
    Helmut Kudrnovsky
    hellik at web.de
    Thu Oct 18 11:40:25 PDT 2018
Markus Neteler wrote
> On Thu, Oct 18, 2018 at 1:59 PM Martin Landa <
> landa.martin@
> > wrote:
>> čt 18. 10. 2018 v 13:42 odesílatel Martin Landa <
> landa.martin@
> > napsal:
>> > About PROJ4/5. My suggestion:
>> New GDAL package is built against PROJ5. Result also PROJ has been
>> switch to PROJ 5. There is backward compatibility package proj4dll
>> which should be used by G74.
> Is this QGIS issue related to it?
> https://gis.stackexchange.com/questions/299313/grass-gis-plugin-not-loading-in-qgis-3
> Markus
> grass-dev mailing list
> grass-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Yes, it looks like there is a dll mismatch.
in mid and long term it will be harder to maintain old releases in an
osgeo4w environment which ist switching to newer library versions.
a good reason to release sooner than later a python3 ready grass and we drop
the older versions depending on old dependencies.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
