[GRASS-dev] [GRASS GIS] #3685: pygrass GridModule: ERROR: Unable to open element file <windows>
trac at osgeo.org
Fri Oct 19 14:34:01 PDT 2018
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: PyGRASS | Version: svn-trunk
Resolution: | Keywords: GridModule
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3685 mlennert]:
> I've been using a script with code resembling the attached python script
for months (notably through the i.cutlines addon), without any error. It
uses the GridModule class from pygrass to run i.zc on tiles of an input
map (as i.zc reads everything into memory).
> I suddenly get the following errors, both with trunk and release76:
> GRASS 7.7.svn (nc_spm_08):~ > ./grid_test.py
> Creating edge map
> ERROR: ERROR: ERROR: UnableUnableUnable toto openopen elementelement
filefile to open<windows> <windows>for elementfor file
> <tmp.grid_test.py.498 at izc_000_002>
> <tmp.grid_test.py.498 at izc_000_003>
> <windows> for
> <tmp.grid_test.py.498 at izc_000_001>
> ERROR: Unable to open element file <windows> for
> <tmp.grid_test.py.498 at izc_000_000>
> ERROR: ERROR: Unable to open element file <windows> for
> <tmp.grid_test.py.498 at izc_001_001>
> <tmp.grid_test.py.498 at izc_001_002>
> <tmp.grid_test.py.498 at izc_001_000>
> <tmp.grid_test.py.498 at izc_001_003>
> <tmp.grid_test.py.498 at izc_002_000>
> <tmp.grid_test.py.498 at izc_002_001>
> <tmp.grid_test.py.498 at izc_002_003>
> <tmp.grid_test.py.498 at izc_002_002>
> ERROR: ERROR: UnableUnable toto openopen elementelement filefile
<windows><windows> forfor
<tmp.grid_test.py.498 at izc_002_002><tmp.grid_test.py.498 at izc_002_003>
> <tmp.grid_test.py.498 at izc_003_001>
> <tmp.grid_test.py.498 at izc_003_000>
> ERROR: <tmp.grid_test.py.498 at izc_003_002>
> <tmp.grid_test.py.498 at izc_003_003>
> Traceback (most recent call last):
> File "./grid_test.py", line 33, in <module>
> grd.run()
> File "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 568, in run
> self.patch()
gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 609, in patch
> self.start_row, self.start_col, self.out_prefix)
gnu/etc/python/grass/pygrass/modules/grid/patch.py", line 79, in
rpatch_map
> rtype.open('r')
gnu/etc/python/grass/pygrass/raster/__init__.py", line 210, in open
> raise OpenError(str_err)
> grass.exceptions.OpenError: The map does not exist, I can't open in 'r'
mode
> Does anyone have any idea what might be going wrong ? When I look into
one of these izc_* directories, I see the following:
> GRASS 7.6.svn (nc_spm_08):~ > ls -l GRASSDATA/nc_spm_08/izc_002_002/
> total 16
> -rw-r--r-- 1 mlennert mlennert 14 oct 19 11:20 CURGROUP
> -rw-r--r-- 1 mlennert mlennert 291 oct 19 11:20 SEARCH_PATH
> -rw-r--r-- 1 mlennert mlennert 81 oct 19 11:20 VAR
> -rw-r--r-- 1 mlennert mlennert 317 oct 19 11:20 WIND
> Does anyone have any idea about what might be going on ? This keeps me
from launching quite long-running processes, so it would be great if I
could solve this rapidly. I have to admit I'm a bit lost even just trying
to understand what might be wrong and how I should debug this. Any hints
are more than welcome.
I think this is related to `gscript.use_temp_region()`. The error messages
are all related to a region named `tmp.grid_test.py.498`, but this region
does not exist in the subsequently created temporary mapset. This
temporary region is defined in the current mapset and only valid in the
current mapset. Other temporary mapsets created later on in the script can
not access this temporary region definition, thus the ERRORs searching for
`tmp.grid_test.py.498` in different mapsets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3685#comment:2>
