[GRASS-dev] Python script dependencies
Nikos Alexandris nik at nikosalexandris.net
Wed Oct 24 02:22:26 PDT 2018
* Stefan Blumentrath <Stefan.Blumentrath at nina.no> [2018-10-24 08:03:58 +0000]:
>Good point!
>Added two bullet-points here: https://trac.osgeo.org/grass/wiki/Submitting
By the way,
g.extension r.green
Fetching <r.green> from GRASS GIS Addons repository (be patient)...
Compiling...
  File "/tmp/grass7-nik-27424/tmpm7f5Qj/r.green/scripts/r.green.hydro.structure", line 139, in <module>
    from libgreen.checkparameter import check_required_columns, exception2error
ImportError: No module named libgreen.checkparameter
make[2]: *** [/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/include/Make/Html.make:14: r.green.hydro.structure.tmp.html] Error 1
Installing...
/usr/bin/install: cannot stat '/tmp/grass7-nik-27424/tmpm7f5Qj/r.green/docs/html/r.green.hydro.structure.html': No such file or directory
make[2]: *** [/osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/include/Make/Script.make:36: install] Error 1
Updating addons metadata file...
Installation of <r.green> successfully finished
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20181024/eabba1d3/attachment.sig>
