[GRASS-dev] Fwd: [release] planning GRASS 7.4.2
Martin Landa
landa.martin at gmail.com
Wed Oct 24 10:13:08 PDT 2018
Dear Jurgen,
to avoid broken GRASS plugin in OSGeo4W for longer time I just wanted
to ask you if you are rebuilding qgis osgeo4w packages automatically
when new GRASS version is published? Should I inform you about new
GRASS version personally or you are following also GRASS ML? For
better cooperation in the future: I could put new grass version to
expr (test) at first, wait for new qgis build and then publish also
grass. What do you think, Ma
---------- Forwarded message ---------
Date: st 24. 10. 2018 v 9:53
Subject: Re: [GRASS-dev] [release] planning GRASS 7.4.2
To: Markus Neteler <neteler at osgeo.org>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
po 22. 10. 2018 v 22:00 odesÃlatel Markus Neteler <neteler at osgeo.org> napsal:
> > > - Final release: 19 Oct
> > if no objection I would suggest to trigger tagging final release.
wingrass packages (osgeo4w and standalone) uploaded. UbuntuGIS
packages will be packaged in the next days. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Martin Landa
