[GRASS-dev] OSGeo4W-winGRASS - using bash in console - scripts not working
Helmut Kudrnovsky hellik at web.de
Wed Oct 24 10:26:37 PDT 2018
just tested following here with [1]:
- OSGeo4W-winGRASS-console: starting bash:
C:\>bash
GRASS 7.4.2>
- to see if env var are still there, e.g.
GRASS 7.4.2> echo $GRASS_PYTHON
C:\OSGEO4~1\bin\python.exe
the variables set beforehand are still there
- starting a binary grass module there:
GRASS 7.4.2> g.region --help
Manages the boundary definitions for the geographic region.
Usage:
 g.region [-dsplectwmn3bgfau] [region=name] [raster=name[,name,...]]
   [raster_3d=name] [vector=name[,name,...]] [n=value] [s=value]
   [e=value] [w=value] [t=value] [b=value] [rows=value] [cols=value]
or
just starts the GUI
- try to start a script module, e.g. r.reclass.area
GRASS 7.4.2> r.reclass.area.bat
/c/OSGEO4~1/apps/grass/grass-7.4.2/bin/r.reclass.area.bat: line 1:
@%GRASS_PYTHON%: command not found
it seems %GRASS_PYTHON%, or in the sense of bash $GRASS_PYTHON, seems not to
be expanded while running bash.
any idea how to get the script modules working?
[1]
System Info
GRASS version: 7.4.2
GRASS SVN revision: r73591
Build date: 2018-10-23
Build platform: x86_64-w64-mingw32
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.0
SQLite: 3.17.0
Python: 2.7.14
wxPython: 2.8.12.1
Platform: Windows-10-10.0.17134 (OSGeo4W)
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
