[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Anna Petrášová kratochanna at gmail.com
Mon Sep 3 06:48:06 PDT 2018
On Mon, Sep 3, 2018 at 2:28 AM Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Sep 3, 2018 at 4:21 AM Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > Hi,
> > I committed the experimental support of Python 3 to trunk (grass77) by
> Sanjeet (GSoC 2018).
> This is excellent, thanks for much for your hard work, Sanjeet, Anna
> and all involved!
> > In the first stage of testing, we need to make sure GRASS can compile
> and run with Python 2 without problems. Python 3 support is highly
> experimental, we are still having problems with ctypes and libraries using
> them. However, you should be able to compile GRASS, launch GUI and run
> modules. I tested it on Ubuntu 16.04 with Python 2.7 and Python 3.5
> (virtualenv), utf8 English locale, other platforms were not tested.
> Could you please post a few lines how to properly do the testing with
> virtualenv?
https://trac.osgeo.org/grass/wiki/Python3Support#Howtotest
also, we have now new small dependency - Python 'six' package
> > For reporting bugs related to this, please create tickets and put
> 'Python3' as keyword (even for problems running GRASS on Python2 related to
> this commit).
> > Anna
> thanks again,
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180903/ff1776db/attachment.html>
