[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Markus Neteler neteler at osgeo.org
Mon Sep 3 13:48:23 PDT 2018
(reducing to grass-dev)
... while I wanted to test, my box fails on "pip install wxpython" in
the virtualenv-3:
[...# 30min later: ...]
    Finding libs for WXAUI                                             : yes
    'configure' finished successfully (1.340s)
    Waf: Entering directory
`/home/mneteler/tmp/pip-install-mwki9u85/wxpython/build/waf/3.6/gtk3'
    [629/868] Linking
build/waf/3.6/gtk3/_glcanvas.cpython-36m-x86_64-linux-gnu.so
    [630/868] Compiling sip/cpp/sip_html2wxWebViewHistoryItem.cpp
    [631/868] Compiling sip/cpp/sip_html2wxWebViewHandler.cpp
    [632/868] Compiling sip/cpp/sip_html2wxWebViewFactory.cpp
    [633/868] Compiling sip/cpp/sip_html2wxWebViewFSHandler.cpp
    ../../../../sip/cpp/sip_html2wxWebViewHistoryItem.cpp: In function
‘PyObject* meth_wxWebViewHistoryItem_GetUrl(PyObject*, PyObject*)’:
    ../../../../sip/cpp/sip_html2wxWebViewHistoryItem.cpp:24:12:
error: ‘::wxWebViewHistoryItem’ has not been declared
              ::wxWebViewHistoryItem *sipCpp;
    ../../../../sip/cpp/sip_html2wxWebViewHistoryItem.cpp:24:12: note:
suggested alternative: ‘sipName_WebViewHistoryItem’
[... tons of sip errors...]
    Waf: Leaving directory
    Build failed
     -> task in '_html2' failed with exit status 1 (run with -v to
display more information)
    Command '"/home/mneteler/grasspy3/bin/python3"
/home/mneteler/tmp/pip-install-mwki9u85/wxpython/bin/waf-2.0.7
--wx_config=/home/mneteler/tmp/pip-install-mwki9u85/wxpython/build/wxbld/gtk3/wx-config
--gtk3 --python="/home/mneteler/grasspy3/bin/python3"
--out=build/waf/3.6/gtk3 configure build ' failed with exit code 1.
    Finished command: build_py (0m8.387s)
    Finished command: build (0m9.512s)
    Command '"/home/mneteler/grasspy3/bin/python3" -u build.py build'
Command "/home/mneteler/grasspy3/bin/python3 -u -c "import setuptools,
tokenize;__file__='/home/mneteler/tmp/pip-install-mwki9u85/wxpython/setup.py';f=getattr(tokenize,
'open', open)(__file__);code=f.read().replace('\r\n',
'\n');f.close();exec(compile(code, __file__, 'exec'))" install
--record /home/mneteler/tmp/pip-record-sdim1_xp/install-record.txt
--single-version-externally-managed --compile --install-headers
/home/mneteler/grasspy3/include/site/python3.6/wxpython" failed with
error code 1 in /home/mneteler/tmp/pip-install-mwki9u85/wxpython/
Any idea?
When simply ignoring the GUI for now:
(grasspy3) [mneteler at oboe ~ ]$ python3 ~/bin/grass76
  File "/home/mneteler/bin/grass76", line 2162, in <module>
    main()
  File "/home/mneteler/bin/grass76", line 2010, in main
    set_paths(grass_config_dir=grass_config_dir)
  File "/home/mneteler/bin/grass76", line 623, in set_paths
    os.environ['MANPATH'] = sys_man_path
  File "/home/mneteler/grasspy3/lib64/python3.6/os.py", line 674, in __setitem__
    value = self.encodevalue(value)
  File "/home/mneteler/grasspy3/lib64/python3.6/os.py", line 744, in encode
    raise TypeError("str expected, not %s" % type(value).__name__)
TypeError: str expected, not bytes
(same error as Martin)
Markus
