[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Anna Petrášová
kratochanna at gmail.com
Mon Sep 3 14:14:49 PDT 2018
On Mon, Sep 3, 2018 at 4:56 PM Anna Petrášová <kratochanna at gmail.com> wrote:
> On Mon, Sep 3, 2018 at 4:48 PM Markus Neteler <neteler at osgeo.org> wrote:
>> Hi,
>> (reducing to grass-dev)
>> ... while I wanted to test, my box fails on "pip install wxpython" in
>> the virtualenv-3:
>> [...# 30min later: ...]
>> Finding libs for WXAUI :
>> yes
>> 'configure' finished successfully (1.340s)
>> Waf: Entering directory
>> `/home/mneteler/tmp/pip-install-mwki9u85/wxpython/build/waf/3.6/gtk3'
>> [629/868] Linking
>> build/waf/3.6/gtk3/_glcanvas.cpython-36m-x86_64-linux-gnu.so
>> [630/868] Compiling sip/cpp/sip_html2wxWebViewHistoryItem.cpp
>> [631/868] Compiling sip/cpp/sip_html2wxWebViewHandler.cpp
>> [632/868] Compiling sip/cpp/sip_html2wxWebViewFactory.cpp
>> [633/868] Compiling sip/cpp/sip_html2wxWebViewFSHandler.cpp
>> ../../../../sip/cpp/sip_html2wxWebViewHistoryItem.cpp: In function
>> ‘PyObject* meth_wxWebViewHistoryItem_GetUrl(PyObject*, PyObject*)’:
>> ../../../../sip/cpp/sip_html2wxWebViewHistoryItem.cpp:24:12:
>> error: ‘::wxWebViewHistoryItem’ has not been declared
>> ::wxWebViewHistoryItem *sipCpp;
>> ../../../../sip/cpp/sip_html2wxWebViewHistoryItem.cpp:24:12: note:
>> suggested alternative: ‘sipName_WebViewHistoryItem’
>> [... tons of sip errors...]
>> Waf: Leaving directory
>> Build failed
>> -> task in '_html2' failed with exit status 1 (run with -v to
>> display more information)
>> Command '"/home/mneteler/grasspy3/bin/python3"
>> /home/mneteler/tmp/pip-install-mwki9u85/wxpython/bin/waf-2.0.7
>> --wx_config=/home/mneteler/tmp/pip-install-mwki9u85/wxpython/build/wxbld/gtk3/wx-config
>> --gtk3 --python="/home/mneteler/grasspy3/bin/python3"
>> --out=build/waf/3.6/gtk3 configure build ' failed with exit code 1.
>> Finished command: build_py (0m8.387s)
>> Finished command: build (0m9.512s)
>> Command '"/home/mneteler/grasspy3/bin/python3" -u build.py build'
>> Command "/home/mneteler/grasspy3/bin/python3 -u -c "import setuptools,
>> tokenize;__file__='/home/mneteler/tmp/pip-install-mwki9u85/wxpython/setup.py';f=getattr(tokenize,
>> 'open', open)(__file__);code=f.read().replace('\r\n',
>> '\n');f.close();exec(compile(code, __file__, 'exec'))" install
>> --record /home/mneteler/tmp/pip-record-sdim1_xp/install-record.txt
>> --single-version-externally-managed --compile --install-headers
>> /home/mneteler/grasspy3/include/site/python3.6/wxpython" failed with
>> error code 1 in /home/mneteler/tmp/pip-install-mwki9u85/wxpython/
>> Any idea?
> it looks like it's missing a package, on ubuntu it's libwebkit-dev
>> When simply ignoring the GUI for now:
>> (grasspy3) [mneteler at oboe ~ ]$ python3 ~/bin/grass76
>> Traceback (most recent call last):
>> File "/home/mneteler/bin/grass76", line 2162, in <module>
>> main()
>> File "/home/mneteler/bin/grass76", line 2010, in main
>> set_paths(grass_config_dir=grass_config_dir)
>> File "/home/mneteler/bin/grass76", line 623, in set_paths
>> os.environ['MANPATH'] = sys_man_path
>> File "/home/mneteler/grasspy3/lib64/python3.6/os.py", line 674, in
>> __setitem__
>> value = self.encodevalue(value)
>> File "/home/mneteler/grasspy3/lib64/python3.6/os.py", line 744, in
>> encode
>> raise TypeError("str expected, not %s" % type(value).__name__)
>> TypeError: str expected, not bytes
>> (same error as Martin)
> working on it, I don't get this because of some settings in my
> environment, which don't get to that line causing the error
Try r73241
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180903/34e1bb6d/attachment.html>
