[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Helmut Kudrnovsky hellik at web.de
Tue Sep 4 11:36:24 PDT 2018
 > >  Deprecated since version 2.7: The optparse module is deprecated and
will not
 >>   be developed further; development will continue with the argparse
module.
>Can you add optparse package? It's weird, it should be part of standard
Python library:
>https://docs.python.org/3.7/library/optparse.html
some tests in the MSYS2/mingw build environment.
outside of an virtual environment
$ python3 --version
Python 3.7.0
$ python3
Python 3.7.0 (default, Aug  3 2018, 11:56:18)  [GCC 8.2.0 64 bit (AMD64)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import optparse
>>> import argparse
inside the virtual environment
$ source Scripts/activate
(grasspy3)
$ python --version
Python 3.7.0
(grasspy3)
$ python3
win32
>>> import optparse
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'optparse'
>>> import argparse
ModuleNotFoundError: No module named 'argparse'
the missing optparse here seems to be a local virtual environment issue.
any idea to how to solve this?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
