[GRASS-dev] [GRASS GIS] #3638: v.distance linear matrix remove duplicate cat column & table associated without having map of distance lines
trac at osgeo.org
Wed Sep 5 04:49:35 PDT 2018
Reporter: Maellevd | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Vector | Version: 7.4.0
Keywords: v.distance | CPU: Unspecified
Platform: Linux |
Hello,
I would like to receive some details related to the v.distance module with
the graphical interface in GRASS 7.4.1.
1) When I try to generate a linear matrix of distances using v.distance, I
observe that the output contains a duplicate column (denoted “to_cat” and
"cat" in the example below).
Is there a reason for that ?
Is there a way to generate a linear matrix of distances without that
duplicated column ?
Here's an example command I ran:
v.distance -p -a from=hospitals at x to= hospitals at x upload=cat,dist
with the following output:
from_cat | to_cat | cat | dist
1 | 1 | 1 | 0
1 | 2 | 2 | 7489.1043632983983
1 | 3 | 3 | 339112.17046729225
2) When creating a table associated with the distance matrix:
a) why do my vector layers need to belong to the current mapsets while the
goal is not to update the vector layers ?
Example:
Command:
v.distance -a from=hospitals at PERMANENT to= hospitals at PERMANENT
output=map_connect_hospital_PERM upload=cat,dist column=to_cat,dist_min
table=tabl_dist_PERM
Output: ERROR: Bug: tentative de mise à jour d'une couche qui n'est pas
dans le jeu de cartes courant
b) why do you have to create a map of distance lines?
Indeed, it seems to me that it would be interesting to generate the table
without having this map.
Example:
Command:
v.distance -a from=hospitals at x to=hospitals at x output=map_connect_hospital
upload=cat,dist column=to_cat,dist_min table=tabl_dist
How to get rid of this "output = map_connect_hospital" option and just get
the table?
Thank you in advance for your feedback on these two concerns
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638>
