[GRASS-dev] [GRASS GIS] #3638: v.distance linear matrix remove duplicate cat column & table associated without having map of distance lines
GRASS GIS trac at osgeo.org
Wed Sep 5 06:28:31 PDT 2018
  Reporter:  Maellevd     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  normal       |  Milestone:
 Component:  Vector       |    Version:  7.4.0
Resolution:               |   Keywords:  v.distance
       CPU:  Unspecified  |   Platform:  Linux
Comment (by mlennert):
 Replying to [comment:3 mlennert]:
 > See r73272 for the fix. I'll backport to the other branches ASAP.
 Done in r73273 and r73275.
 > I'll attach a patch with these enhancement (plus some attempt at
 cleaning up parser dependency instructions. This will partly change the
 module API, though, so we'll have to decide how to apply.
 Also done. This patch creates a new (-s) flag which allows to output a
 square matrix if desired. By default the module will output a linear
 matrix, whatever the number of upload variables.
 The patch also allows creating a table without creating a map and allows
 to determine column names in output, even when using -p or table=.
 Please test.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:5>
