[GRASS-dev] [GRASS GIS] #3639: Write table like output directly to database
trac at osgeo.org
Wed Sep 5 06:35:25 PDT 2018
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 8.0.0
Component: Database | Version: svn-trunk
Resolution: | Keywords: table,database,write
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
In v.distance this is already available. I don't know if the solution is
sufficiently general, and the outputs generated by the modules
sufficiently similar to consider v.distance's code as boiler plate that
can be integrated elsewhere. One issue is column types that need to be
correctly defined. For the raster modules those will have to be determined
from the input raster maps.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3639#comment:1>
