[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Jürgen E. Fischer
jef at norbit.de
Sat Sep 8 04:32:57 PDT 2018
Hi Martin,
On Tue, 04. Sep 2018 at 16:36:03 +0200, Martin Landa wrote:
> út 4. 9. 2018 v 16:22 odesílatel Jürgen E. Fischer <jef at norbit.de> napsal:
> > Also added a wxpython transitional package that depends on python-wx.
> > msys-grass and in turn grass6 still depend on it.
> I would prefer to avoid any transitional packages if possible. I have
> updated grass6 setup.ini to use new python-wx package instead. Ma
Without it people would install python-wx while keeping wxpython with the same
set of files (ie. deinstalling wxpython later would not remove python-wx, but
all of it files).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180908/e4ef3882/attachment-0001.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180908/e4ef3882/attachment-0001.ksh>
