[GRASS-dev] Issue with v.external.out and GPKG
Markus Neteler
neteler at osgeo.org
Thu Sep 13 07:10:21 PDT 2018
I am a bit at a loss with v.external.out and GPKG:
grass76 ~/grassdata/nc_spm_08_grass7/user1/
outdir=/tmp/rast2vect/
mkdir -p $outdir
v.external.out output=$outdir format=GPKG
g.region raster=landclass96 -p
r.to.vect input=landclass96 output=landclass96 type=area column=landuse
Extracting areas...
100%
Writing areas...
100%
Registering primitives...
Building areas...
100%
Attaching islands...
100%
Attaching centroids...
100%
Warning 1: The '' extension is not allowed by the GPKG specification,
which may cause compatibility problems
ERROR 1: A file system object called '/home/mneteler/rast2vect/' already exists.
WARNING: Unable to create OGR data source '/home/mneteler/rast2vect/'
WARNING: Unable to create vector map <landclass96>
r.to.vect complete.
v.external.out -p
dsn: /home/mneteler/rast2vect/
format: GPKG
# cease connection
v.external.out -r
This Warning 1 likely comes from GDAL/OGR since no file extension is
provided. But how to use that properly?
r.to.vect input=landclass96 output=landclass96.gpkg type=area column=landuse
WARNING: Illegal vector map name <landclass96.gpkg>. Character '.' not
allowed.
ERROR: Unable to create vector map: <landclass96.gpkg> is not SQL compliant
WARNING: Invalid vector map name <>
Maybe v.external.out lacks an extension= parameter? Or any other trick?
thanks
Markus
