[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Anna Petrášová
kratochanna at gmail.com
Thu Sep 13 13:30:42 PDT 2018
On Tue, Sep 4, 2018 at 2:00 AM Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Sep 4, 2018 at 12:39 AM Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > are you sure you did make distclean?
> You are right, solved with that.
> Here a few more issues: At wxGUI startup:
> # seen in the terminal:
> from grass.pygrass.vector import VectorTopo
> File
> "/home/mneteler/software/grass77/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/vector/__init__.py",
> line 7, in <module>
> import grass.lib.vector as libvect
> File
> "/home/mneteler/software/grass77/dist.x86_64-pc-linux-gnu/etc/python/grass/lib/vector.py",
> line 5863
> PORT_LONG_MAX = 2147483647L
> SyntaxError: invalid syntax
regarding this issue, make sure you compile GRASS with Python 3. I get this
if I compile it with Python2 and then open it with Python 3.
Anna
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180913/5b7e6d64/attachment.html>
