[GRASS-dev] Issue with v.external.out and GPKG
Markus Metz
markus.metz.giswork at gmail.com
Fri Sep 14 01:17:51 PDT 2018
On Thu, Sep 13, 2018 at 5:03 PM Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> čt 13. 9. 2018 v 16:10 odesílatel Markus Neteler <neteler at osgeo.org>
napsal:
> > v.external.out output=$outdir format=GPKG
> $outdir should point to GPKG file not to directory, eg.
> v.external.out output=/tmp/test.gpkg format=GPKG
> Unfortunately r.to.vect still fails:
> Copying features...
> WARNING: Boundary is not closed. Feature skipped.
> WARNING: Unable to write feature in vector map <landclass96>
> WARNING: Writing new feature failed
> It would require fix.
this won't fix because topological areas can only be converted to
non-topological polygons after all boundaries and centroids have been
written out and after topology has been built.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180914/0380fc73/attachment.html>
