[GRASS-dev] [GRASS GIS] #3641: python3/ctypes: ctypes.ArgumentError: argument 2: <type 'exceptions.TypeError'>: expected LP_struct_Cell_head instance instead of LP_struct_Cell_head
Moritz Lennert
mlennert at club.worldonline.be
Fri Sep 14 06:38:59 PDT 2018
On 13/09/18 16:59, Anna Petrášová wrote:
> I can't reproduce it with the example from manual.
Ok, I'll try to see if I can create a reproducible test cast.
Moritz
> It's obviously a ctypes problem, that's one of the issues I haven't been
> able to solve, although I thought this comes up only with Python 3, not
> 2. That's why I wanted to branch 7.6 first because I knew it might take
> some time to get these problem fixed in trunk.
> On Thu, Sep 13, 2018 at 8:49 AM Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> Hi Anna,
> Any idea where this comes from ? It currently keeps me from using trunk.
> Moritz
> instead of
> > LP_struct_Cell_head
> > Reporter: mlennert | Owner: grass-dev@…
> > Type: defect | Status: new
> > Priority: normal | Milestone: 7.8.0
> > Component: Python | Version: unspecified
> > Keywords: Python3 ctypes | CPU: Unspecified
> > Platform: Unspecified |
> > In a script using i.cutlines which in turn uses GridModule I
> suddenly get
> > the following error using trunk:
> > Traceback (most recent call last):
> > File "/home/mlennert/.grass7/addons/scripts/i.cutlines", line
> 673, in
> > <module>
> > main()
> 278, in
> > main
> > grd.run()
> > File
> "/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
> > gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 568,
> in run
> > self.patch()
> > File
> > gnu/etc/python/grass/pygrass/modules/grid/grid.py", line 609,
> in patch
> > self.start_row, self.start_col, self.out_prefix)
> > File
> > gnu/etc/python/grass/pygrass/modules/grid/patch.py", line 91, in
> > rpatch_map
> > rpatch_row(rast, rrasts, rbbox)
> > File
> > gnu/etc/python/grass/pygrass/modules/grid/patch.py", line 41, in
> > rpatch_row
> > sei = get_start_end_index(bboxes)
> > File
> > gnu/etc/python/grass/pygrass/modules/grid/patch.py", line 25, in
> > get_start_end_index
> > r_start, c_start = coor2pixel((bbox.west, bbox.north), reg)
> > File
> > gnu/etc/python/grass/pygrass/utils.py", line 180, in coor2pixel
> > return (libraster.Rast_northing_to_row(north, region.byref()),
> > I do not have this error with 7.6.
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
