[GRASS-dev] [GRASS GIS] #3156: Cannot export GRASS raster map using r.out.png (crashes on windows)
trac at osgeo.org
Fri Sep 14 12:46:47 PDT 2018
Reporter: spawley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.7
Component: Raster | Version: 7.0.4
Resolution: | Keywords: r.out.png, wingrass, g.ppmtopng
CPU: x86-64 | Platform: MSWindows 7
Comment (by wenzeslaus):
Replying to [comment:18 mmetz]:
> Replying to [comment:17 mmetz]:
> > Replying to [comment:16 wenzeslaus]:
> > > [...] Perhaps it was just considered to be superseded by r.out.gdal?
> > r.out.png and r.out.tiff create something like a screenshot using the
current region settings: the output contains only coloring information.
This can be changed with r.colors.
> > r.out.gdal exports cell values using the current region settings: the
output contains the original cell values.
> > r.out.png and r.out.tiff have been superseeded by the button to "Save
display to file" in the map display.
> Not exactly, "Save display to file" does not produce a georeferenced
screenshot, while r.out.tiff and r.out.png do produce a georeferenced
screenshot.
Thank you for clarification. That's exactly how I used r.out.png, to
create something like a "georeferenced screenshot".
Than it is clear that "Save display to file" is not a good replacement
because it is not georeferenced and it is not a module. The georeferencing
could be added. I think there is even a ticket for that. However, using it
as module is not possible, although d.out.file is pretty close.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3156#comment:19>
