[GRASS-dev] [GRASS GIS] #3631: Mapset remains locked after switch to it and exit
trac at osgeo.org
Sat Sep 15 18:11:45 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.6.0
Component: Startup | Version: svn-trunk
Resolution: fixed | Keywords: init, grass.py, lock, gislock,
CPU: | g.mapset
Unspecified | Platform: Linux
Changes (by wenzeslaus):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"73335" 73335]:
#!CommitTicketReference repository="" revision="73335"
init: remove lock from the current mapset (fixes #3631)
Do not remove lock based on the path to the initially locked file,
but instead use the rc file point to by GISRC (assumed stable within this
proccess)
to find out the current mapset and remove lock file there.
Now a sequence start in mapset A, switch to B, exit removes all lock
files.
Before, only the A lock file was removed, specifically the lock file was
left
in the mapset exited from.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3631#comment:3>
