[GRASS-dev] [GRASS GIS] #3635: Suspicious use and cleanup of the mapset tempoary directory
trac at osgeo.org
Sat Sep 15 20:13:57 PDT 2018
Reporter: wenzeslaus | Owner: wenzeslaus
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: init grass.py clean_temp .tmp temp
CPU: | g.mapset wxGUI rendering
Unspecified | Platform: All
Comment (by wenzeslaus):
Now only the `clean_temp` tool is used. It is called through
`atexit.register()`. `clean_temp` always cleans the current mapset
(specified in an "rc file" pointed to by GISRC variable as for all GRASS
modules).
What is now possible but was broken before:
1. Start session I in mapset A.
2. Switch session I to mapset B.
3. Start session II in mapset A.
3. Start processes in session II (mapset A).
4. Exit session I (from mapset B).
5. Running processes in session II (mapset A) still have their temporary
files.
Before r73336, the processes in session II would fail because their
temporary files were deleted. The positive aspect of this behavior was
that the cleanup of the original mapset would take care of the files left
behind by GUI which was putting some of its rendering files to the mapset
temporary directory, but this is no longer needed after r73334 (#3637).
By relying only on `clean_temp` and not deleting whole `.tmp` manually
(leaving aside the mapset switching problem), there are two changes in
behavior:
1. The `.tmp` directory and the `$HOSTNAME` subdirectory are never deleted
once created. The content is cleaned by `clean_temp` which applies its
rules rather than deleting all.
2. When a process does not end in a standard way, e.g. by pressing
''Stop'' button in the wxGUI, the process may still show up when
`clean_temp` tests if the process associated with the file by PID in the
file name is still running (by sending the null signal; applies only to
other than `__MINGW32__` systems). Consequently, some files may be left
behind when exiting the session (or changing mapset - that did not
change). These files should be usually clean by the next session running
in that mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3635#comment:6>
