[GRASS-dev] [GRASS GIS] #3649: Cartographic composer: OK, pointer and pan buttons do not work
GRASS GIS trac at osgeo.org
Tue Sep 18 18:45:39 PDT 2018
 Reporter:  veroandreo   |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.6.0
Component:  wxGUI        |    Version:  svn-trunk
 Keywords:  g.gui.psmap  |        CPU:  Unspecified
 Platform:  Linux        |
 The buttons "Pointer" and "Pan" in the Cartographic composer do not work
 properly, neither does the OK button when adding maps or decorations.
 The "pointer" does not allow to select and move map elements as it used to
 do (it does nothing basically) and the "pan" zooms instead of panning.
 Furthermore, every time I add a map layer or decoration, the button OK
 does not close the dialog box. Instead, I have to close with the "x" in
 the corner.
 This prevents from using G7:g.gui.psmap to produce any reasonable output
 map.
 System Info:
 GRASS version: 7.7.svn
 GRASS SVN revision: r73362
 Build date: 2018-09-18
 Build platform: x86_64-pc-linux-gnu
 GDAL: 2.2.4
 PROJ.4: 4.9.3
 GEOS: 3.6.1
 SQLite: 3.22.0
 Python: 2.7.15
 wxPython: 3.0.2.0
 Platform: Linux-4.18.7-200.fc28.x86_64-x86_64-with-fedora-28-Twenty_Eight
 Is there any further testing I can do?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3649>
