[GRASS-dev] [GRASS-user] Error on opening workspace
Vaclav Petras wenzeslaus at gmail.com
Thu Sep 20 10:24:37 PDT 2018
[Removing grass-user as this is more grass-dev or bug tracking thing.]
On Thu, Sep 20, 2018 at 12:27 PM Frank David <frank.david at geophom.fr> wrote:
> Hello,
> Grass 7.4 (and 7.5) failed to open a workspace (with many layers and
> folders). The waiting box stay open and the workspace is not fully loaded.
> If I try to save the current workspace, I got the following message :
> "Échec d'écriture des paramètres de l'espace de travail courant.
Hi, back translating using a po file, it says
"Writing current settings to workspace file failed."
So it looks like saving, not loading workspace. Based on the None for cmd
below and something I noticed in the past, I would say it is saving with a
layer dialog open, but OK or Apply was not pressed. Can you please test it
if that's it and open a ticket with steps to reproduce it?
Best,
Vaclav
> Raison: 'NoneType' object has no attribute 'GetCmd'
> Traceback (most recent call last):
>    File "/usr/local/grass-7.5.svn/gui/wxpython/lmgr/frame.py", line
> 1656, in SaveToWorkspaceFile
>      WriteWorkspaceFile(lmgr=self, file=tmpfile)
>    File "/usr/local/grass-7.5.svn/gui/wxpython/core/workspace.py", line
> 900, in __init__
>      self.__writeLayer(mapTree, item)
> 959, in __writeLayer
>      item, key='maplayer').GetCmd(
> AttributeError: 'NoneType' object has no attribute 'GetCmd'"
> I run Grass on Debian9
> Regards
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180920/221547b2/attachment.html>
