[GRASS-dev] r.tileset and cs2cs / cct
Stefan Blumentrath Stefan.Blumentrath at nina.no
Fri Sep 21 06:44:21 PDT 2018
On my Ubuntu 16.04 box I get the following error message in GRASS 7.4.1 (package install from UbuntuGIS) with r.tileset:
r.tileset sourceproj=+init=epsg:25833 maxrows=10000 maxcols=10000 | wc -l
ERROR: cs2cs program not found, install PROJ.4 first:
       http://proj.maptools.org
ERROR: cs2cs failed
0
And locate tells me that there indeed is no cs2cs on my PATH/system...
Is that related to the move to Proj.5?
Can GRASS even be installed without Proj?
Is that a GRASS issue, a packaging issue or simply an installation issue?
r.tileset should probably be updated to use cct https://proj4.org/development/migration.html (yet, I cannot find cct on my system either)...
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180921/cde71522/attachment.html>
