[GRASS-dev] [GRASS GIS] #3651: Missing classification from v.lidar.edgedetection
trac at osgeo.org
Fri Sep 21 13:07:50 PDT 2018
Reporter: balagates | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: 7.4.0
Resolution: | Keywords: lidar, edgedetection
CPU: OSX/Intel | Platform: MacOSX
Comment (by mmetz):
Replying to [ticket:3651 balagates]:
> The man page for v.lidar.edgedetection describes
> The output will be a vector map in which points has been classified as
TERRAIN, EDGE or UNKNOWN.
> On the "output" I see a database table named <name>_edge_interpolation
with columns
> Column 1: ID:INTEGER:20
> Column 2: Interp:REAL:20
This table is attached to layer 3 holding interpolation results for
internal use.
> I do not see a table for output=<name> nor do I see the following
> TERRAIN (cat = 1, layer = 1)
> EDGE (cat = 2, layer = 1)
> UNKNOWN (cat = 3, layer = 1)
This is correct, there is no table attached to layer 1. Category values
are stored with the geometries. You can display points classified as
terrain with `d.vect layer=1 cats=1`.
> Later steps in the workflow at the bottom of the man page do not provide
all the output I expect, presumable because this classification is
missing.
The classification is not missing, it is stored as category values without
an attribute table.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3651#comment:2>
