[GRASS-dev] [GRASS GIS] #3656: cannot launch GRASS GIS 7.4.1 gis_set error
trac at osgeo.org
Mon Sep 24 11:01:13 PDT 2018
Reporter: cgarzon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.2
Component: Startup | Version: 7.4.0
Resolution: | Keywords: gis_set error, python
CPU: Unspecified | Platform: MacOSX
Changes (by neteler):
* keywords: gis_set error => gis_set error, python
* component: Default => Startup
* milestone: => 7.4.2
Old description:
> I have the following problem: When I try to open GRASS GIS 7.4.1 (or
> 7.4.0) I get "Gis_set error 'es_CO' cannot be set" and the program
> immediately shuts down. I have a Mac OS High Sierra 10.13.6. This is the
> error message I get:
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> Default locale not found, using UTF-8
> WARNING: Default locale settings are missing. GRASS running with C
> locale.
> Cleaning up temporary files...
> access: No such file or directory
> ERROR: LOCALIZACIÓN </Users/Gabriela/Documents/Los
> Andes/Biología/grassdata/nc_spm_08_grass7> no disponible
> Starting GRASS GIS...
> Traceback (most recent call last):
> File
> "/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/gis_set.py",
> line 1236, in OnInit
> StartUp = GRASSStartup()
> File
> line 233, in __init__
> self._set_properties(grassVersion, grassRevisionStr)
> File
> line 286, in _set_properties
> self.OnSetDatabase(None)
> File
> line 985, in OnSetDatabase
> self._showError(_("Path '%s' doesn't exist.") % gisdbase)
> File
> line 511, in _showError
> self.lmessage.SetLabel(_("Error: {text}").format(text=text))
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xed' in
> position 48: ordinal not in range(128)
> OnInit returned false, exiting...
> Carol.
New description:
WARNING: Default locale settings are missing. GRASS running with C locale.
File
File
File
File
File
Carol.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3656#comment:1>
