[GRASS-dev] area calculations in several GIS
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Sep 26 06:52:42 PDT 2018
FYI:
Here are GRASS area measures for the given geometry:
In WGS84: 14718097678.6716
In UTM 33 (an appropriate UTM CRS): 14707741818.1113
So, in WGS84, GRASS is as close to Planimeter as most of the other GIS (that probably also use WGS84, "on the fly")...
curl https://gist.githubusercontent.com/kbevers/207b5bcb9be20e7554abe5f56742ec2c/raw/5bf6cd03bb1d03e86523f1602664567b4de8198e/ellipsoidal_area.geojson -o ellipsoidal_area.geojson
# In WGS84 location:
v.in.ogr input=/home/user/ellipsoidal_area.geojson layer=ellipsoidal_area output=area_test
v.to.db -p map=area_test option=area
# In UTM 33N location:
v.proj --overwrite location=wgs84 mapset=PERMANENT input=area_test smax=100 output=area_test
For those with special interest in historic discussion on area measurements in QGIS, see:
https://issues.qgis.org/issues/12057
(for example)
Cheers
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Helmut Kudrnovsky
Sent: tirsdag 25. september 2018 19:38
To: grass-dev at lists.osgeo.org
Subject: [GRASS-dev] area calculations in several GIS
fyi see
https://lists.osgeo.org/pipermail/qgis-developer/2018-September/054644.html
with GRASS mentioned
Kristian Evers:
Right, here are the calculated areas as returned by a number of different GIS applications and the planimeter app of GeographicLib for reference:
Caris LOTS: 14.737 km^2
ArcMap:     14.727,446 km^2
MapInfo:    14.727,352 km^2
GeoMedia:   14.726,443 km^2
Planimeter: 14.722,522 km^2
QGIS 3.2:   14.652,181 km^2
QGIS 2.8:   14.652,181 km^2
The polygon that I have used to get the numbers above can be found here:
https://gist.github.com/kbevers/207b5bcb9be20e7554abe5f56742ec2c
I am quite confident that GeographicLib delivers the most accurate result (if you have doubts, this reference [0] should convince you). As can be seen from the table above all but QGIS come fairly close. I expect some variation in the results as these are numerical approximations, although I think QGIS is too far of the mark. My suspicion is that the geodesic algorithm used by QGIS (and apparently GRASS) is to blame here.
/Kristian
[0] https://arxiv.org/pdf/1102.1215.pdf
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
grass-dev mailing list
https://lists.osgeo.org/mailman/listinfo/grass-dev
