[GRASS-dev] [GRASS GIS] #461: v.to.db crashes on a shapefile connected with v.external
GRASS GIS trac at osgeo.org
Thu Sep 27 02:38:30 PDT 2018
  Reporter:  msieczka  |      Owner:  grass-dev@…
      Type:  defect    |     Status:  closed
  Priority:  major     |  Milestone:  7.0.7
 Component:  Vector    |    Version:  svn-trunk
Resolution:  fixed     |   Keywords:  v.external, v.to.db
       CPU:  x86-64    |   Platform:  Linux
Changes (by martinl):
 * status:  new => closed
 * resolution:   => fixed
Old description:
> Backtrace:
> GRASS 6.5.svn (javier):~ > gdb v.to.db
> GNU gdb 6.8-debian
> Copyright (C) 2008 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later
> <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show
> copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu"...
> (gdb) run map=gshhs_shp opt=area units=k col=AREA
> Starting program: /usr/local/grass-6.5.svn/bin/v.to.db map=gshhs_shp
> [Thread debugging using libthread_db enabled]
> warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at
> 0000000000000120
> [New Thread 0x7fe8946c9710 (LWP 9814)]
> Reading areas...
>  100%
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 0x7fe8946c9710 (LWP 9814)]
> 0x00007fe89418f539 in db_get_column_sqltype (column=0x0) at column.c:107
> 107         return column->sqlDataType;
> (gdb) bt
> #0  0x00007fe89418f539 in db_get_column_sqltype (column=0x0) at
> column.c:107
> #1  0x00007fe8938f480d in db_select_int (driver=0x9237ba0, tab=0x98bb7f0
> "gshhs", col=0x98b8ba0 "", where=0x0, pval=0x7fff9c7ff858) at
> select.c:138
> #2  0x00000000004069f2 in update (Map=0x7fff9c7ff8c0) at update.c:53
> #3  0x00000000004043e4 in main (argc=5, argv=0x7fff9c7fffd8) at main.c:84
New description:
 Backtrace:
 GNU gdb 6.8-debian
 There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
 https://trac.osgeo.org/grass/ticket/461#no3"x86_64-linux-gnu"...
 0000000000000120
 Reading areas...
  100%
 (gdb) bt
 column.c:107
 "gshhs", col=0x98b8ba0 "", where=0x0, pval=0x7fff9c7ff858) at select.c:138
Comment:
 Originally reported bug seems to be fixed. Free free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/461#comment:18>
