[GRASS-dev] [GRASS GIS] #3621: Cannot create map frame in cartographic composer
GRASS GIS trac at osgeo.org
Thu Sep 27 12:17:01 PDT 2018
  Reporter:  cmbarton     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  critical     |  Milestone:  7.4.2
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:  map frame, cartographic composer
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by cmbarton):
 The issue with setting the map frame is now fixed. I was able to give a
 full test and ran into 2 other issues which I'll mention here. One is
 already reported and a serious problem. The other is less so but makes the
 cartographic composer unusable for most purposes. We can keep this open
 for these cartographic composer issues or move them to another ticket
 because they are different from the map frame per se.
 Issue 1: Cannot select point symbols. This also affects the vector
 display, which is very serious. Here is the error when you click on the
 button to select a symbol.
   File "/Applications/GRASS-7.6.app/Contents/Resources/gui/w
 xpython/psmap/dialogs.py", line 3149, in OnSymbolSelection
 currentSymbol=self.symbolName.GetLabel())
 xpython/gui_core/dialogs.py", line 2067, in __init__
 self._layout()
 xpython/gui_core/dialogs.py", line 2073, in _layout
 fgSizer = wx.FlexGridSizer(rows=2, vgap=5, hgap=5)
 TypeError
 FlexGridSizer(): arguments did not match any overloaded
 call:
   overload 1: 'hgap' is not a valid keyword argument
   overload 2: 'hgap' is not a valid keyword argument
   overload 3: 'hgap' is not a valid keyword argument
   overload 4: 'hgap' is not a valid keyword argument
 Issue 2. You cannot add a scale bar. All the other items can be added.
 Just not a scale bar. Here is the error:
 xpython/psmap/frame.py", line 686, in OnAddScalebar
 dlg = ScalebarDialog(self, id=id, settings=self.instruction)
 xpython/psmap/dialogs.py", line 4776, in __init__
 self.panel = self._scalebarPanel()
 xpython/psmap/dialogs.py", line 4947, in _scalebarPanel
 self.sbCombo = wx.combo.BitmapComboBox(panel,
 style=wx.CB_READONLY)
 AttributeError
 'module' object has no attribute 'combo'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:13>
