[GRASS-dev] [GRASS GIS] #1715: Preview on cartographic composer broken
trac at osgeo.org
Fri Sep 28 09:14:34 PDT 2018
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.7
Component: wxGUI | Version: svn-trunk
Resolution: worksforme | Keywords: cartographic composer
CPU: Unspecified | Platform: Unspecified
Comment (by cmbarton):
This works as long as ps2pdf is installed. Otherwise it will fail and may
even lock up the GUI occasionally. This means that ghostscript needs to be
a listed dependency if it is not already
Ticket URL: <https://trac.osgeo.org/grass/ticket/1715#comment:6>
