[GRASS-dev] [GRASS GIS] #3772: Make the grass library importable outside of a GRASS session
GRASS GIS trac at osgeo.org
Mon Apr 1 01:26:28 PDT 2019
  Reporter:  pmav99       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Python       |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mlennert):
 Replying to [comment:8 pmav99]:
 > Added a patch that makes it possible to import the GRASS library even
 from a normal shell session.
 > After applying the patch and compiling, the code can be tested with:
 > LD_LIBRARY_PATH=dist.x86_64-pc-linux-gnu/lib PYTHONPATH=dist.x86_64-pc-
 linux-gnu/etc/python python -c 'import grass.script' && echo 'OK!'
 > The patch itself does 2 things:
 > 1. It does not resolve the path to {{{GISBASE}}} by using the ENV
 variable but by using the relative path from {{{dist.x86_64-pc-linux-
 gnu/etc/python/grass/__init__.py}}}
 I have to admit I don't really understand why all this code is necessary
 just to be able to do
 LD_LIBRARY_PATH=/usr/lib/grass74/lib
 PYTHONPATH=/usr/lib/grass74/etc/python python -c 'import grass.script' &&
 echo 'OK!
 instead of
 GISBASE=/usr/lib/grass76 LD_LIBRARY_PATH=/usr/lib/grass76/lib
 PYTHONPATH=/usr/lib/grass76/etc/python python -c 'import grass.script' &&
 echo 'OK!
 or even
 GISBASE=/usr/lib/grass76 LD_LIBRARY_PATH=$GISBASE/lib
 PYTHONPATH=$GISBASE/etc/python python -c 'import grass.script' && echo
 'OK!'
 Since you have to know the GISBASE path anyhow to be able to set
 LD_LIBRARY_PATH and PYTHONPATH ?
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/3772#comment:10>
