[GRASS-dev] [GRASS GIS] #3772: Make the grass library importable outside of a GRASS session
trac at osgeo.org
Tue Apr 2 12:53:25 PDT 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Python | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:11 pmav99]:
> Well, the next steps are to get rid of {{{PYTHONPATH}}} and
{{{LD_LIBRARY_PATH}}} too. {{{PYTHONPATH}}} should be rather easy via a
path configuration file (e.g. {{{grass.pth}}} -
[https://docs.python.org/3/library/site.html source]). Not sure how easy
is going to be to get rid of {{{LD_LIBRARY_PATH}}} but at least in theory
if you figure out the appropriate linker options, it is doable.
I still don't understand why you want to load the GRASS Python library
outside a GRASS session: you can't use it unless a GRASS session with a
`GISRC` file containing `GISDBASE`, `LOCATION_NAME`, and `MAPSET` has been
defined, otherwise GRASS executables will fail.
Setting `PYTHONPATH` and `LD_LIBRARY_PATH` is not sufficient: `PATH` must
include the path to GRASS executables, otherwise the GRASS Python library
will not work because it calls GRASS executables which are expected to be
in `PATH`.
Moreover, you can't just set `PYTHONPATH` and `LD_LIBRARY_PATH`, you need
to prepend or append the corresponding GRASS paths if `PYTHONPATH` or
`LD_LIBRARY_PATH` are already set.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3772#comment:12>
