[GRASS-dev] [GRASS GIS] #3806: db.copy: fails with pg as to_driver
trac at osgeo.org
Fri Apr 5 02:33:09 PDT 2019
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Database | Version: unspecified
Keywords: db.copy | CPU: Unspecified
Platform: Linux |
db.copy fails to open a pg connection.
Tried syntax from the example as well as syntax as used in v.out.ogr.
Might make sense to unify the way DB connection strings are handled in
different modules... As the pg driver usage in db.copyis inconsistent with
e.g. v.in.ogr or v.out.ogr.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3806>
