[GRASS-dev] which files are mandatory for raster maps
Markus Neteler
neteler at osgeo.org
Tue Apr 16 09:10:25 PDT 2019
Hi Moritz,
On Tue, Apr 16, 2019 at 2:56 PM Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> Hello,
> I'm working with a large batch of raster maps (4550 * 4 bands) and
> including all the auxiliary files this explodes my inode quota on our
> university's HPC system.
Out of curiosity, which file system is that?
> While waiting to see if they can increase this,
> I was wondering which of the auxiliary files are absolutely mandatory.
> Can I just erase colr/* and hist/* for example ?
I just tried:
r.info elevation
WARNING: Unable to get history information for <elevation@>
[rest as usual]
So, it should not be a problem.
# idea r.external:
I just checked, it seems that r.external generates the same amount of
files, hence not helpful in this regard.
# idea find directories with most inode consumption (source [1]):
for i in `ls -1A | grep -v "\.\./" | grep -v "\./"`; do echo "`find $i
| sort -u | wc -l` $i"; done | sort -rn | head -10
Maybe you can still delete something?
Markus
[1] https://talk.plesk.com/threads/inode-full-no-more-space.296442/
PS: it happened to me in the past when exporting XFS over NFS (while
it worked ok inside the HPC system). In the end I had to reformat the
disk array...
