[GRASS-dev] [GRASS GIS] #3805: Export vector map (table with column name, which is reserved PostgreSQL keyword) into the PostGIS database
GRASS GIS trac at osgeo.org
Tue Apr 16 09:14:07 PDT 2019
  Reporter:  tmsz      |      Owner:  grass-dev@…
      Type:  defect    |     Status:  closed
  Priority:  normal    |  Milestone:  7.6.2
 Component:  Database  |    Version:  svn-releasebranch76
Resolution:  fixed     |   Keywords:  v.out.postgis
       CPU:  All       |   Platform:  All
Changes (by neteler):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"74386" 74386]:
 #!CommitTicketReference repository="" revision="74386"
 libvector: support reserved PostgreSQL keywords as column name by quoting
 when exporting vector map to PostGIS database (contributed by tmsz; fixes
 #3805)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3805#comment:1>
