[GRASS-dev] [GRASS GIS] #3806: db.copy: fails with pg as to_driver
GRASS GIS trac at osgeo.org
Wed Apr 17 13:23:31 PDT 2019
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.8.0
 Component:  Database     |    Version:  unspecified
Resolution:               |   Keywords:  db.copy
       CPU:  Unspecified  |   Platform:  Linux
Comment (by sbl):
 Thanks for the info. Will try and update the manual accordingly as it
 currently lacks info about the required db.login step...
 It might be still worth considering to unify module syntax (e.g. using
 whitespace instead of comma for separating elements of the connection
 string) as well as using .pgpass file... Even if it is just minor
 cosmetics, it would help making things a bit more intuitive...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3806#comment:2>
