[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
trac at osgeo.org
Thu Apr 18 05:57:14 PDT 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression zstd zlib
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:2 mlennert]:
> Replying to [comment:1 mmetz]:
> > Replying to [ticket:3815 mlennert]:
> > > I would plead [...] for libzstd to become a compulsory requirement
for GRASS GIS, and for the configure script to default to --with-zstd=yes.
> > Done in trunk r74391. The default is now `--with-zstd=yes`, you can
disable ZSTD support with `--with-zstd=no`. To be backported I guess.
> +1 for backporting.
Done in relbr76 r74398
> Should libzstd be added to REQUIREMENTS.html ?
Yes, done in r74396,9 (trunk, relbr76)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:3>
