[GRASS-dev] [GRASS GIS] #3819: Add test coverage of C files
trac at osgeo.org
Thu Apr 18 08:02:04 PDT 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone:
Component: Compiling | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by rouault):
> GDAL is already using gcov/lcov, too, so it might make sense to see how
they have integrated them
This is quite messy to be honest. Partly because I didn't try to make this
better :-) So basically, I've a job that forks the GDAL master branch and
re-applies the following changes on top of it :
https://github.com/rouault/gdal_coverage/commit/3b63c70890a0897dcbe1cbd49f36b76e0a5e704a
But the gist is build with lcov, run the tests, run lcov, filter some
stuff in its output to have a clean report, run genhtml and then push this
to a github repo. The interesting part that could be more or less reused
by GRASS is in
#diff-46c965c7db8bedae7518f42e783c44dd
Ticket URL: <https://trac.osgeo.org/grass/ticket/3819#comment:2>
