[GRASS-dev] [GRASS GIS] #3820: Error i.pansharpen in grass76 relbranch
GRASS GIS trac at osgeo.org
Thu Apr 18 14:28:59 PDT 2019
  Reporter:  veroandreo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.6.2
 Component:  Imagery      |    Version:  svn-releasebranch76
Resolution:               |   Keywords:  i.pansharpen
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by veroandreo):
 It does work in trunk with no reported errors. However, if I run it in
 trunk compiled with python 3 in a virtualenv, I get:
 i.pansharpen red=lsat7_2002_30 at PERMANENT   green=lsat7_2002_20
 blue=lsat7_2002_10 pan=lsat7_2002_80 method=ihs   output=lsat7_2002_ihs
 Using 8bit image channels
 Performing pan sharpening with hi res pan image: 14.250000
 Transforming to IHS color space...
  100%
 Histogram matching...
  100%
   File "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-
 gnu/scripts/i.pansharpen", line 632, in <module>
     main()
 gnu/scripts/i.pansharpen", line 259, in main
     ihs(pan, ms1, ms2, ms3, out, pid, sproc)
 gnu/scripts/i.pansharpen", line 380, in ihs
     panmatch = matchhist(pan, target, outname)
 gnu/scripts/i.pansharpen", line 552, in matchhist
     stats = stats_out.communicate()[0].split('\n')[:-1]
 TypeError: a bytes-like object is required, not 'str'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3820#comment:1>
