[GRASS-dev] [GRASS GIS] #3822: Tests for r.basins.fill are broken
trac at osgeo.org
Fri Apr 19 05:54:30 PDT 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
These tests are broken both for python 2 and python 3:
- {{{raster/r.basins.fill/testsuite/testrbf.py}}}
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2019-03-26-07-00/report_for_nc_spm_full_v2alpha_nc/raster/r.basins.fill/testrbf/index.html
Moreover, the testsuite [https://github.com/GRASS-GIS/grass-
ci/blob/8161cae6d4df311d6560e305644673834c8f7f01/raster/r.basins.fill/testsuite/testrbf.py#L24-L25
overwrites the "elevation" and "geology"] maps thus ruining the test
dataset (at least on python 3):
before running the tests:
./exec_grass.sh r.univar elevation
Starting GRASS GIS...
Cleaning up temporary files...
Executing <r.univar elevation> ...
100%
total null and non-null cells: 29535
total null cells: 0
Of the non-null cells:
n: 29535
minimum: 89.6269
maximum: 134.301
range: 44.6739
mean: 116.855
mean of absolute values: 116.855
standard deviation: 9.32828
variance: 87.0169
variation coefficient: 7.98278 %
sum: 3451315.7405014
Execution of <r.univar elevation> finished.
Cleaning up default sqlite database ...
after:
100%
total null cells: 29535
n: 0
minimum: -nan
maximum: -nan
range: -nan
mean: -nan
mean of absolute values: -nan
standard deviation: -nan
variance: -nan
variation coefficient: -nan %
sum: -nan
Until someone finds the time to fix them, please add the following
decorator on the Test class:
import unittest
@unittest.skip("See #3822")
class TestRasterbasin(TestCase):
Ticket URL: <https://trac.osgeo.org/grass/ticket/3822>
