[GRASS-dev] [GRASS GIS] #3822: Tests for r.basins.fill are broken
trac at osgeo.org
Sat Apr 20 15:00:19 PDT 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Tests | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:2 mmetz]:
> Replying to [comment:1 neteler]:
> > After renaming the maps (see attached patch) the test passes here.
> Does it make sense to adjust tests to a test location that is 1) not
available,
It is available:
http://fatra.cnr.ncsu.edu/data/
> 2) in alpha state?
In the end I only restored the names of the standard sample data set and
found that the tests works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3822#comment:3>
