[GRASS-dev] [GRASS-SVN] r74422 - grass/trunk/lib/python/pygrass/modules/interface/testsuite
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Apr 24 15:04:02 PDT 2019
Hi again,
#3825 was opened for not forgetting it.
But indeed, issuing a warning message makes sense if test is run individually.
As mentioned, in multirunner it should be visible (0 tests succeeded).
Cheers,
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Markus Neteler
Sent: onsdag 24. april 2019 23:42
To: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] [GRASS-SVN] r74422 - grass/trunk/lib/python/pygrass/modules/interface/testsuite
<svn_grass at osgeo.org<mailto:svn_grass at osgeo.org>> schrieb am Mi., 24. Apr. 2019, 22:33:
Author: sbl
Date: 2019-04-24 13:33:36 -0700 (Wed, 24 Apr 2019)
New Revision: 74422
   grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py
temporarily deactivate for Python 3; see #3825
Modified: grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py
--- grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py       2019-04-24 20:33:02 UTC (rev 74421)
+++ grass/trunk/lib/python/pygrass/modules/interface/testsuite/test_pygrass_modules_interface_doctests.py       2019-04-24 20:33:36 UTC (rev 74422)
@@ -39,4 +39,8 @@
 if __name__ == '__main__':
-    grass.gunittest.main.test()
+    # Temporarily skip test for Python 3
+    if sys.version_info[0] > 2:
+        pass
+    else:
+        grass.gunittest.main.test()
IMHO there should be at least a message... Like this the skipped test will be forgotten quickly.
Just my 0.02 cents,
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190424/aceb91e9/attachment-0001.html>
