[GRASS-dev] [GRASS GIS] #798: r.in.gdal : subdataset handling
trac at osgeo.org
Fri Apr 26 09:34:01 PDT 2019
Reporter: rouault | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: unspecified
Resolution: | Keywords: r.in.gdal
CPU: All | Platform: All
Comment (by marisn):
Replying to [comment:7 mmetz]:
> Subdatasets are now (trunk r74373) printed if present, no flag needed.
Thanks. Still I am not certain if printing anything more than a warning
should not be done only on a request. Let it stay like this unless someone
can show an use case where it would be a bad thing.
> Related but independent of that, import fails early if no raster bands
are found.
This is a good question. If no bands are specified, all bands are
imported. Following this logic, all subdatasets should be imported. Still
I do understand why it could be a bad idea ;-)
> What exactly is the advantage of another new option "subdataset" instead
of providing the name of the subdataset to be imported? In any case, you
need to read the names and descriptions of the available subdatasets
first.
The names of subdatasets can be really verbose and thus hard to handle.
Besides, subdatasets are not supported in r.import. Such option would make
it a bit easier to implement it.
Here's an example of how import of subdataset looks like now (yes, thats
208 symbols for a subdataset name and 251 symbol for whole import command
and that's without any extras!):
r.in.gdal
input=/home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip
output=S2A_MSIL2A_20180413
WARNING: Input contains subdatasets which may need to be imported
separately by name:
Subdataset 1:
Name:
SENTINEL2_L2A:/vsizip//home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.SAFE/MTD_MSIL2A.xml:10m:EPSG_32634
Subdataset 3:
Name:
SENTINEL2_L2A:/vsizip//home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.SAFE/MTD_MSIL2A.xml:20m:EPSG_32634
Subdataset 5:
Name:
SENTINEL2_L2A:/vsizip//home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.SAFE/MTD_MSIL2A.xml:60m:EPSG_32634
Subdataset 7:
Name:
SENTINEL2_L2A:/vsizip//home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.SAFE/MTD_MSIL2A.xml:TCI:EPSG_32634
ERROR: No raster bands found in
</home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip>
r.in.gdal
input=SENTINEL2_L2A:/vsizip//home/marisn/data/S2_2018/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.zip/S2A_MSIL2A_20180413T095031_N0207_R079_T34VFH_20180413T102702.SAFE/MTD_MSIL2A.xml:10m:EPSG_32634
Besides the import works easy only form CLI, as in GUI simple copy/paste
contains line wrapping symbols that need to be removed first. Thus being
able to provide an option subdataset=1,3 would make it short and easy (1st
run – get a list of subdatasets; add subdataset number(s); 2nd run to
finish import). Subdataset option, of course, would not conflict with
specifying subdataset name directly as input parameter thus keeping
current functionality unchanged.
Ticket URL: <https://trac.osgeo.org/grass/ticket/798#comment:8>
