[GRASS-dev] OSGeo4W winGRASS77svn: TypeError: endswith first arg must be bytes or a tuple of bytes, not str
Helmut Kudrnovsky
hellik at web.de
Sat Apr 27 04:56:03 PDT 2019
just tried to start the latest OSGeo4W winGRASS77svn daily build:
C:\>grass77svn
Starting GRASS GIS...
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\gis_set.py", line 34, in
<module>
from core import globalvar
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\globalvar.py", line
35, in <module>
from core.debug import Debug
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line 77,
in <module>
Debug = DebugMsg()
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line 39,
in __init__
self.SetLevel()
File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line 45,
in SetLevel
self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
File "C:\OSGEO4~1\apps\grass\grass77\etc\python\grass\script\core.py",
line 1074, in gisenv
s = read_command("g.gisenv", flags='n', env=env)
line 494, in read_command
process = pipe_command(*args, **kwargs)
line 463, in pipe_command
return start_command(*args, **kwargs)
line 393, in start_command
return Popen(args, **popts)
line 54, in __init__
cmd = shutil_which(args[0])
File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in which
if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in <genexpr>
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
grass77 --help
See also: https://grass.osgeo.org/grass77/manuals/helptext.html
Exiting...
Drücken Sie eine beliebige Taste . . .
anyone any idea?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
