[GRASS-dev] [GRASS GIS] #3486: v.in.ogr/v.out.ogr: default format in online manual
GRASS GIS trac at osgeo.org
Sat Apr 27 23:04:13 PDT 2019
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.6.2
 Component:  Docs         |    Version:  unspecified
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by Sylvain POULAIN):
 Replying to [comment:20 mmetz]:
 > Replying to [comment:19 Sylvain POULAIN]:
 > > Problem is about wxgui sorry for this misunderstanding !
 > > With v.in.ogr, GPKG is not present in file listing but is present in
 directory (I didn't notice that until today). Even with that, you could
 not select gpkg from file with the GUI ("v.in.ogr -f | grep GPKG" is ok !)
 > > With r.out.gdal, it's not present in the list but could be changed
 manually. ("r.out.gdal -l | grep GPKG" is ok !
 > > But Idea is : some promotes gpkg but it's not totally support in Grass
 Gui (r.in.gdal is ok)
 > I see. Changed in trunk r74122, the GUI knows now about GeoPackages.
 Sorry for the late answer, Yes it works now since 7.6.2
 Many thanks !
Ticket URL: <https://trac.osgeo.org/grass/ticket/3486#comment:24>
