[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
trac at osgeo.org
Sun Apr 28 08:43:40 PDT 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression zstd zlib
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:13 mmetz]:
> Replying to [comment:12 neteler]:
> > Please note that this change in 7.6 contradicts our release
announcement:
> > https://trac.osgeo.org/grass/wiki/Release/7.6.0-News#Librarychanges
> > "libraster: ZSTD is now the default compression if available"
> The release announcement for 7.6.2 should then include something like
> The default compression has been changed back to ZLIB, even if ZSTD
compression is available, because not all currently supported systems
provide ZSTD with standard package management tools, and because problems
were encountered regarding compatibility with different ZSTD 1.3.x
versions.
Added in new draft: https://trac.osgeo.org/grass/wiki/Release/7.6.2-News
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:14>
