[GRASS-dev] [GRASS GIS] #2857: d.rast.num fails in GUI because the constrain display resolution fails
trac at osgeo.org
Mon Apr 29 05:26:07 PDT 2019
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.5
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: display resolution, d.rast.num,
CPU: | mapdisp, rendering
Unspecified | Platform: Linux
Comment (by veroandreo):
I cannot reproduce the reported issue with grass 76 relbranch, I only get
the usual warning when the region I try to show is larger than 200 x 200:
Failed to run command 'd.rast.num map=class_spot_dec2017_10c at dengue_cba'.
Details:
GRASS_INFO_WARNING(32567,1): Current region size: 1153 rows X 1793 cols
GRASS_INFO_WARNING(32567,1): Your current region setting may be too large.
Cells displayed on your graphics window may be too small for cell category
number to be visible.
GRASS_INFO_END(32567,1)
GRASS_INFO_ERROR(32567,2): Aborting (region larger then 200 rows X 200
cols is not allowed)
GRASS_INFO_END(32567,2)
I'd suggest to close this one
Ticket URL: <https://trac.osgeo.org/grass/ticket/2857#comment:13>
