[GRASS-dev] [GRASS GIS] #3831: d.grid: -g and -w flags do not display any grid
GRASS GIS trac at osgeo.org
Tue Apr 30 05:01:34 PDT 2019
  Reporter:  veroandreo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:  7.6.2
 Component:  Display      |    Version:  svn-releasebranch76
Resolution:  invalid      |   Keywords:  d.grid
       CPU:  Unspecified  |   Platform:  Linux
Changes (by veroandreo):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 Indeed! And it also works as expected in wx monitors. Thanks for the heads
 up :)
 If -g or -w is to be used in a projected location (no need to use them if
 location is latlon), size must be in degrees and not really in map units
 (m or other).
 Closing as invalid (should have read the manual more carefully)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3831#comment:2>
