[GRASS-dev] [GRASS GIS] #3833: pygrass.gis.region.Region + WIND_OVERRIDE + non-existing path kills the process
trac at osgeo.org
Tue Apr 30 10:45:03 PDT 2019
process
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: PyGRASS | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
OK, the problem seems to be that the generated gis.py (i.e.
{{{lib/python/ctypes/OBJ.x86_64-pc-linux-gnu/gis.py]}}}), doesn't define
{{{errcheck}}} for some of the functions, including {{{G_get_window}}} and
{{{G_get_element_window}}}. Can anyone provide a hint, why these functions
don't have {{{errcheck}}} defined while others do?
Some relevant links:
- [https://stackoverflow.com/questions/24349806/catch-exception-in-ctypes-
based-on-c-exit-code SO question]
- The same problem was solved
[https://github.com/DECODEproject/zenroom/issues/47#issuecomment-446173032
here] using
[https://docs.python.org/3/library/ctypes.html#ctypes._FuncPtr.errcheck
ctypes.errcheck]
- [https://stackoverflow.com/questions/50669907/how-to-use-ctypes-errcheck
SO example using errcheck]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3833#comment:1>
